"Tags" Endpoints - POST Create tag
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/tags
Create workspace tags.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/tags".to_string()).json(&serde_json::json!(\{"name":"string"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Body​
name string Tag name
items Array of object -
items​
at string When was created/last modified
creator_id integer CreatorID the user who created the tag
deleted_at string When was deleted
id integer Tag ID
permissions string -
Possible errors:
  • Invalid JSON input
  • tag name can’t be blank
  • a tag with the name ‘{tag_name}’ already exists
Only organization or workspace administrators may manage tags in this workspace.
