Monthly reports
A colleague has asked if it is possible for me to provide monthly reports instead of weekly ones. I can’t see this is possible - is this because I am using the free version or am I simply looking in the wrong place?
You should be able to generate monthly reports in Toggl regardless of which plan you’re using. When you’re in the reports section, look for the time period selection options where you can choose your reporting interval. You can select monthly as your preferred view rather than weekly.
If you’re having trouble locating this option, check the reports settings or filters to adjust the reporting period. The ability to customize report timeframes is available across all plan types, so this isn’t a free version limitation.
Many thanks - will do.
