When will the new reporting come into place (and taken away from free plan)?
Hello,
I just saw this blog post and I am not super happy about it, because as a sole proprietor it’s not easy to get work done, when permanent change is happening in the SaaS world.
That means the reports go away in the free plan. When will this happen?
I simply don’t have the time to deal with this now as similar things are happening with every other software, plugin, SaaS, etc.
Having a date would be good for better planing
Hey @markus, we understand your frustration, but the three main free reports — Summary, Detailed, Workload (previously named ‘Weekly’) — will remain free, including the options to use filters with them.
As for the 2 newly-named reports:
  1. Profitability (previously Insights) has always been a paid feature.
  2. “My Reports” / custom reports (previously Analytics), was communicated as custom dashboards/charts with the intention of it to be a paid feature. However, this is advanced reporting meant for larger teams. The advanced filters have always been a paid feature.
If you’re using one of the 3 main free reports, I would like to know if there’s anything in the article that raised your alarm bells and gave you the impression that Reports are going to be removed. We want to communicate this clearly to our users, and if you’ve got that impression, we must have not be clear somewhere and would like to correct it.
Hello @olivia
I chatted about this already with your colleague (the chatbot suggested first to post in the community, eventually though I got a reply in the chat that’s why the discussion is happening in two places now)
Here is one hint about Custom Reports (or maybe it’s called My Reports), however I see that it’s not so easy to understand terminology especially when changes impact exactly those.
Note for Free users: Custom report creation will no longer be available on the Free plan. You’ll still see the titles of your previous custom reports, but they won’t be accessible or editable.
To be honest, since Analytics was introduced it became a bit more difficult to understand what is Analytics, Reports, Dashboard, Custom Report, My Reports, Insights. It’s all somewhat doing the same. I think you probably want to simplify this as it grew into something that is not so easy to understand.
From a user point of view: there are updates being rolled out, new features, some of them you need time to figure out how you can use them, maybe even adapt a process. Eventually you find a solution for yourself (e.g. I created 2 Dashboards in Analytics) and then it’s taken away, and I start from scratch.
So how I see it now after I spent quite some time on it, Analytics is moving to Reports, and Reports won’t be accessible anymore which includes the Dashboards.
What I am seeing now as free “Dashboards” will become the paid “My Reports” - did I understand this correctly?
Hi @markus,
Yes, all the reports got confusing, that’s why we’re simplifying them.
I see, you are using Analytics, then yes…
… this is correct and you will lose the dashboards you’ve created. Do you mind telling me what type of dashboards you are creating? Usually the 3 default reports are good enough for single users, and we always try to do creative workarounds to get the results free users need.
Hi @olivia
sure, so I created 2 Dashboards:
1st - Client Overview
I am seeing a table, each row is a client, each column is a month. Default view shows all clients, I can quickly filter to only show a single client
2nd - Project Overview
Similar, only that the rows are projects and the columns are again months. For instance, I have a single client and this single client has 3 projects: “clientname ongoing support”, “clientname custom project 1”, “clientname custom project 2”.
In the particular case the ongoing support is a flat rate, custom project is charged separatly. I can’t price based on the report but I can get an overview.
I am using Toggl for years, and a once or twice a year I try to re-think my workflow, tracking, charging, communication to client etc. to make it work with Toggl. That’s a slow process, as I cannot just change anything how I want it. So every change in Toggl that is taking something away of course impacts me again.
What do you think about those reports / dashboards? Particularly as Toggl became a bit complicated over the years (hence the streamlining attempt now on your end) I might miss some things.
Thanks
Markus
Hi @markus,
Apologies for the late reply, I had to confirm some stuff with the product team. So while we are not 100% sure of all the changes, I believe you can get the same reports on the free plan, though it does come with some limitations. In the new Workload report, when you choose “Last semester” or “This semester”** in the date picker, the table data is characterized by months in the columns. You can then group by Project or Client. So something like this…
**The limitation is using “semester” in your date picker — this is set by default so you can’t use other time durations such as “Last year” to see data for the whole year as the columns turn to Q1, Q2, Q3 and Q4 for simplicity.
Let me know if I got the idea of your reports correctly. We are rolling this out to free users first in the coming weeks, feel free to enable Beta to test around.
Hi @olivia
that looks definitely interesting - I just wonder why it’s limited to semester. Is it a UX topic or because of differentiating it from the paid plans.
Of course it makes sense to have the flexibility like I have now to set the time frame myself, e.g. quarter, this year, last year
It gets close to the previous report it seems, except for setting the period / time frame myself.
Hi @markus, currently, it’s a UI/UX decision for simplicity… although if the time-frame flexibility is implemented eventually, it is possible that it will be placed as a paid plan feature. It is always worth a shot to request for the feature though :slight_smile:
Hi @olivia - do you know when the beta reports will be available in the API? (or maybe they are already??) Thanks!
Hi @avoca999, there are no plans in the near future for the Beta Reports API (the current V3 Reports API will not go away). What specific capabilities would you like to use in the API? I can double-check with the team about it.
@olivia The equivalent of the beta Workload Report - specifically, the Weekly report but with Task as well as Project included. Thanks!
Hey @avoca999, sorry, our devs assured that it is definitely coming in the future, but we don’t have a specific timeline at the moment.
Ha ha, OK that’s great, thanks for looking into it!
Hello,
Why can’t I see any reports in the free plan now?
In my free account, the fields for my team are grayed out in the report filters, and I can’t run any reports?
