Request: Toggl 2.0 multi edit entries
Toggl 2.0
Topic content
I have been using Toggl 1 for a couple of years and switched to Toggl 2.0 since last week. One thing I’m having a hard time with is that I can only edit one entry at a time in the web view. I think it is a great addition, that the currently running entry is displayed.
My workflow is as follows:
Start tracking time on a project. Write what I’m doing currently. Now I have a lot of project switching, meaning I will log on one project for like half an hour, then work on a second project for 2h and get back to the first project. I will do different tickets on the first project. At the end of the day I want to have a text of all the tickets I worked on and what I did. This results in me having a lot of small time entries, sometimes 5-7 for a single project in a given day.
In Toggl 1 I could just add the project to the time entries and write what I did at the end of the day. With toggl 2.0 this is not possible. I need to edit every single entry. Which feels so cumbersome, that I want to switch back to Toggl 1.
Have you considered adding back bulk edit functionality?
Best Regards, Marcus
Hi! You can still bulk edit in 2.0. It’s under the Reports > Time Logs report and on the Timer > Time log view.
Hello,
Thanks for the answer, this works as a workaround!
I still think the way toggle 1 handled this is a lot more elegant:
  • Description: Just click the aggregated description and edit directly. The description is displayed as what it is. In Toggl 2 the description is removed in the bulk edit and I need to retype everything or copy the text before to edit it.
  • Project: Just click the aggregated project and change directly
For now the bulk edit works for me but is a bit cumbersome.
Thank you for the answer. I would love it if you could consider some changes
Best regards, Marcus
That’s good feedback! Let me pass it to our team :slight_smile:
