Running entry on menu bar on MacOS become less informative
Why does running entry on menu bar on MacOS not show seconds like before?
Could you please revert it like before?
Previously, it showed seconds. Now, it doesnt show it. Seconds is important information to be known on menu bar
Thanks in advance.
Hi there,
Thanks for your patience.
Unfortunately, yes, we have removed the option to see seconds on the menu bar. Your feedback has been shared with the team however!
Best,
Hi @mizanrahman_07
Thanks for your patience!
The macOS status bar will show the duration as before and you would be able to enable “Show seconds” too.
Yours will see it soon after the next app restart (or approximately after the 24h if you already launched the app today)
Thanks!
