“Saved reports” Endpoints - POST Export CSV for saved report
https://api.track.toggl.com/reports/api/v3/shared/{report_token}.csv
Downloads a previously saved report in csv.
Authentication
A public report is accessible by anyone, a private one is only accessible by the report’s owner or workspace admin. If the criteria aren’t met it returns 403 status code.
Parameters
The report can be executed without parameters, and in this case the saved or default parameters will be used.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/reports/api/v3/shared/{report_token}.csv".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Returns report information in csv form
Possible error messages:
  • report_type does not exist in params
  • The report period is not supported
401​
  • Unable to extract authentication data
  • Incorrect username and/or password
  • Invalid token
  • Workspace was not found or the report’s owner is no longer active on it
404​
Not found
parameter since is missing
