"Saved reports" Endpoints - POST Load the previously saved report
https://api.track.toggl.com/reports/api/v3/shared/{report_token}
Returns the previously saved report.
Authentication
A public report is accessible by anyone, a private one is only accessible by the report’s owner or workspace admin. If the criteria aren’t met it returns 403 status code.
Parameters
The report can be executed without parameters, and in this case the saved or default parameters will be used.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/reports/api/v3/shared/{report_token}".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Returns report information
detailed_results object -
dictionaries object -
features object -
fixed_daterange boolean -
hide_amounts boolean -
input_params object -
is_commenting_enabled boolean -
public boolean -
report_name string -
report_type string -
saved_params object -
summary_results object -
weekly_results object -
workspace_logo string -
detailed_results​
report Array of object -
totals object -
report​
billable boolean -
billable_amount_in_cents integer -
client_name string -
currency string -
description string -
email string -
hourly_rate_in_cents integer -
project_color string -
project_hex string -
project_id integer -
project_name string -
row_number integer -
tag_ids Array of integer -
tag_names Array of string -
task_id integer -
task_name string -
time_entries Array of object -
user_id integer -
username string -
time_entries​
at string -
at_tz string used by reports v2 proxy
id integer -
seconds integer -
start string -
stop string -
totals​
graph Array of object -
labour_cost_in_cents integer -
rates Array of object -
resolution string -
seconds integer -
tracked_days integer -
graph​
by_rate object -
seconds integer -
by_rate​
rates​
billable_seconds integer -
currency string -
dictionaries​
clients object -
filters object Remove it after FlexQ release.
projects object -
tags object -
tasks object -
user_groups object -
users object -
clients​
filters​
clients object -
projects object -
tags object -
tasks object -
users object -
clients​
projects​
tags​
tasks​
user_groups​
users​
projects​
tags​
tasks​
user_groups​
users​
features​
input_params​
saved_params​
summary_results​
report object -
totals object -
report​
groups Array of Object -
totals​
resolution string -
seconds integer -
graph​
by_rate object -
seconds integer -
by_rate​
rates​
currency string -
weekly_results​
totals object -
report​
billable_amounts_in_cents string -
billable_seconds string -
currency string -
hourly_rate_in_cents integer In cents
planned_task_id integer -
project_hex_color string -
seconds string -
user_id integer -
user_name string -
totals​
resolution string -
seconds integer -
graph​
by_rate object -
seconds integer -
by_rate​
rates​
currency string -
Possible error messages:
  • report_type does not exist in params
  • The report period is not supported
401​
  • Unable to extract authentication data
  • Incorrect username and/or password
Invalid token
404​
Not found
report is too big to be exported
