https://api.track.toggl.com/reports/api/v3/shared/{report_token}.xlsx
Downloads a previously saved report in xlsx.
Authentication
A public report is accessible by anyone, a private one is only accessible by the report’s owner or workspace admin. If the criteria aren’t met it returns 403 status code.
Parameters
The report can be executed without parameters, and in this case the saved or default parameters will be used.
- cURL
- Go
- Ruby
- JavaScript
- Python
- Rust
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> { let client = Client::new().basic_auth("<email>", "<password>"); let json = client.request(Method::POST, "https://api.track.toggl.com/reports/api/v3/shared/{report_token}.xlsx".to_string()) .header(CONTENT_TYPE, "application/json") .send() .await? .json() .await?; println!("{:#?}", json); Ok(())}
Response
200
Returns report information in xlsx form
400
Possible error messages:
- report_type does not exist in params
- The report period is not supported
401
- Unable to extract authentication data
- Incorrect username and/or password
403
- Invalid token
- Workspace was not found or the report’s owner is no longer active on it
404
Not found
500
parameter since is missing
