Set by default not working
Your Question/Topic: The following settings are not working:
  • Set new projects as "billable” by default
  • Set new projects as ”public” by default
Even though I have checked those settings, new projects are still not billable and private. Any tips? Also the chat with support -button is still not working as discussed previously in another topic…
Thanks for reporting this issue. A few things to try:
First, make sure you’re adjusting these settings in the right place. You can access your workspace settings by clicking the Settings button in the left sidebar, or by going directly to Toggl Track. The default billable and public settings should be available there.
If you’ve confirmed the settings are checked but new projects still aren’t being created as billable or public, try these steps:
  1. Log out completely and log back in to refresh your session
  2. Clear your browser cache and cookies
  3. Try creating a new project to see if the settings apply to it
If the issue persists after trying these steps, there may be something specific about your workspace configuration that needs attention. These settings should work once properly configured, so if they’re still not applying, something unexpected might be happening.
Regarding the chat button issue you mentioned, that’s a separate problem you may want to look into as well, but I’d focus on confirming the default project settings are being saved correctly first.
