Some of my projects became greyed out and now I cannot access them.
I don’t know why but they are set as “Private”.
I’m on a free plan but this has nothing to do with the trial finish as it happened way before that.
How can I make them public again so I can have access to these projects?
Cheers!
Private projects in Toggl Track are a Premium feature. When a workspace is downgraded from a paid plan to the free plan, projects that were set to Private become locked and appear greyed out.
To access those projects again, you would need to upgrade to a Premium plan to be able to change the privacy settings back to public.
As a workaround on the free plan, you can still create new public projects and move forward with those, though the greyed out private projects would remain inaccessible without upgrading.
That doesn’t seem to be a great response.
I don’t even understand why were they set as private as I’m the only one on my organization. Maybe it was my mistake, I can give you that.
Can someone at Toggl please set these projects as “Shared”?
Thank you.
I just noticed today the ability to set them Public again. I’m not sure if it was there all along or if you added it now, but problem solved.
Thank you.
