Does the sync from toggl track to toggl plan work for you?
Hello
I’m experiencing an issue with the integration between Toggl Track and Toggl Plan.
When I create a project in Toggl Plan, it syncs correctly to Toggl Track.
However, when I create a project in Toggl Track, it does not appear in Toggl Plan, even though I have the integration fully enabled.
Here are my current integration settings in Toggl Plan:
  • :white_check_mark: Sync private projects: Enabled (projects should appear as public in Plan)
  • :white_check_mark: Sync tasks: Enabled
  • :white_check_mark: Import all active data: Enabled
  • :white_check_mark: Correct workspace selected
I’ve verified that the projects in Toggl Track are:
  • Active
  • In the correct workspace
  • Not archived
Could you please help me understand why new projects created in Toggl Track are not syncing to Toggl Plan? Does this work for you?
Best regards
Hi @vonweb: Welcome to our community! Thanks for bringing this to our attention. Our team is aware of the issue and is working on resolving it. If you’re not affected by the issue I’m referring to, you can try disabling and re-enabling the integration. This might resolve the Track > Plan sync issue you’re experiencing. If that doesn’t help, we’ll keep you posted on the fix we’re working on.
Hi @Support,
thanks for the quick reply!
Unfortunately, disabling and re-enabling the integration didn’t help.
Would be great if you could fix the issue on your end – looking forward to the update.
Best regards
I’ve DM’d you @vonweb
Hi! I also have the same issue. I work on free subscriptions in track and plan. Is there a option for syncing clients and projects from track to plan? Tahnks!
Hello! Our Plan/Track integrates the two, so projects and clients are synced: Toggl Track integration - Toggl Plan Help Center
Hi! Thank You for answer. The integration took a night in my case, I checked while ago and now all clients and projects are in plan also. Best regards!
