If I start tracking some work at 10pm, and finish at 1am. I expect that to be three hours, with two hours on one day, and one one the next day. But sadly it just logs two hours.
For instance see here. Wednesday has no hours logged.
Hey @yjhgjhgj
When you start a time entry on a Tuesday and end it the following day the time tracked will only count towards the day you started it.
You would have to split the time entry in order to have it count towards both days.
Hope that helps!
Hi, thanks for your fast reply.
that seems disappointing. I thought the point of this app is to track the time I record.
So I need to go back and check every day I work if I work past midnight, then go in and make two entries to replace the one going over midnight?
If the app doesn’t track time past midnight I recommend making it explicit. ie throw an error to the user saying the time isn’t being tracked/recorded and force stop it at midnight.
Or better yet - fix this bug ![]()
looking back at my logged hours I see this has occurred many times. This has cost be hundreds of dollars in hours which are from previous months and now can’t be invoiced.
