Todoist integration in android
Hi,
I am seeking to replicate the Todoist Web App integration with Toggl on my Android phone. Currently, I start the timer from the Todoist web app, which allows the task title to automatically populate in the timer. This process is efficient when I am using my work laptop. How can I achieve similar functionality on my Android device? The apps appear to be distinct on the mobile platform, and I suspect that the Toggl button is not accessible in the mobile web version of Todoist. I would like guidance on how to streamline this process, as my tasks require timing and I prefer to avoid the extra steps of switching to the Toggl app to activate the timer. This interruption undermines my productivity. Ideally, I would like to manage all my tasks within Todoist— is this achievable?
Furthermore, I have a compatible Android watch, but I have been unable to locate a Toggl application for it.
Hi @Vimal_Vijayan :wave:
I’m afraid we do not have any native integrations with other mobile apps. You are correct in assuming that the Toggl Button is only available with web applications of other tools, as it is a browser extension and can only live in the browser.
The best approach I can come up with would be using a third-party tool to integrate Todoist and Track, for example:
I hope this helps! Noting down your comment as a feature request and sharing it with the team :slight_smile:
