Toggl Tracker button not appearing in Notion pages
Hi,
The Toggl Tracker button (start timer) in Notion pages are no longer appearing for the past few days. Is this a bug? I remember using the button in Notion pages in May but starting from June 1st, the buttons are no longer visible in Notion (with other pages, Google Sheets, Gmail, etc., it works fine). I am currently using Toggl Track Chrome extension Version 4.11.13.
Same here! Haven’t been able to fix it, no matter how much I refresh the page or change the settings…
Hey all! This is fixed in an upcoming update to the extension. Just keep it updated and you should get the fix!
Hi, I updated to the latest version (4.11.15), but the track button is still not appearing in Notion.. I tried re-installing and refreshing the pages but still no luck..
Hi! Please try this:
Disable Notion’s integration in the extension and then switch it back on. You will need to approve the permissions, and that should fix it.
