Toggle is not recognizing my workspace billable rate
Post Title: Toggle is not recognizing my workspace billable rate in invoices, reports, anywhere
Your Question/Topic: I’ve set up my workspace billable rate. I’ve applied the workspace billable rate to projects and noted the projects’ time as billable. When I create an invoice, create a report, drilldown into a single project, etc it shows 0 billable hours and $0 billable amount.
I’ve done a hard refresh. I’ve logged in and out of Toggl. No dice.
**EDIT: I upgraded to Premium subscription to retroactively change billable rate for previous time entries. But when I actually try to do that, the button to do so just doesn’t do anything. I click the pink “Change rate starting from …” button and NOTHING HAPPENS. It just sits there.
@E_San thanks for posting!
When you run into this issue, can you confirm if you are bulk editing projects on the Projects page and changing the historical rate for multiple projects at once? Or are you editing rates by editing details for individual projects?
Does logging out and logging back into the app help? Do you have any more granular rates set up for project members or tasks within projects?
Hi, thanks for the reply! I have tried bulk editing and individual and neither works. Logging out and back in didn’t work either, and I don’t have more granular rates set up for members or projects. It seems like it’s just not accepting the retroactive date.
I’m having the same issue. Did you find a solution for this? I made some projects, set a workspace-wide billable rate, and then started logging hours. All of the projects are showing at $0 despite being set up as billable.
No I haven’t. So far I’ve had to go back through each entry and mark individually as billable. Which is a waste of time.
Thanks for replying. It’s strange, and maybe my problem is slightly different. My logs are already displayed as saying “Billable flag is always on for this project” and the $ is purple, but it doesn’t record the amount in the project page. It says, for instance, I have 18 billable hours for a project, but the Billable Amount is 0 USD. I don’t know how to get it to notice my rates and calculate the amount at all. I thought it’d be automatic, but maybe I’m missing something?
@bptog @E_San please check your DM - I’d like to have the team look into this for your future and will need some additional private info about your account.
Sorry for the wait and thanks for your patience :raised_hands:
My issue is slightly different where Toggl isn’t recognizing the correct historic billable rate. It allowed me to change the rate on a project. The change was effective on the 1st of a month but the rate didn’t actually change for entries on the 1st of the month, only after the date I requested the change. Toggl won’t let me fix the incorrect entries or calculations.
Hey there! When you changed the rate, did you choose “today” or a specific date range?
I picked the date I wanted it to change (Feb 1). It apparently defaulted to “today” (which was about 2 weeks later). I’m simply trying to fix the 2 weeks of incorrect rates but it won’t let me change those. Do I have to delete and reenter those time entries?
Please note: the email notification I received indicated I could respond by replying to that email, but your server rejected the email, so I’m reposting my response here.
Hello! You should be able to attempt another Historical Rate change using the February 1 date once more to see if that helps
This seems to be a recurring problem. I added a team member with a different billable rate. I had a project with a custom rate, which I changed back to the default billable rates. I selected the option to change the data as of a specific date (April 1). Although the project has been edited, none of the billable rates on / after April 1 are using the default rate, only the previous custom rate on that project. The report is generated incorrect hourly rates and it’s becoming a hassle to have to manually edit these issues. It’s also a key reason why I have not connected Toggl to quickbooks.
