Hi! This means that the preferences in your workspace are setup so that you can not save (stop) a time entry if it is not marked as billable, as explained here: Enforce Billable Time Tracking
To mark a time entry as billable, click the “$” icon next to the duration of the running timer. Then, edit the duration to reflect the correct time before stopping it.
