"Workspaces" Endpoint - POST Alerts
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/alerts
Handles POST alert requests.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/alerts".to_string()).json(&serde_json::json!(\{\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Body​
request Object Alert data
client_id integer -
client_name string -
errors Array of object -
id integer -
object_type integer -
project_color string -
project_id integer -
project_name string -
receiver_groups string -
receiver_roles string -
receiver_users string -
receivers integer -
source_kind string -
threshold integer -
threshold_type string -
thresholds string using pq types is a workaround to enable reading postgres arrays into go types we should wrap these pq types to avoid polluting our domain
wid integer -
errors​
code string -
message string -
Possible errors:
  • invalid workspace ID
  • source kind can’t be blank
  • project can’t be blank
  • project not supported for this source kind
  • threshold type can’t be blank
  • thresholds can’t be blank
  • receivers can’t be blank
  • alert type out of range
  • receiver type out of range
  • threshold out of range
  • source kind out of range
  • threshold type out of range
  • receiver role out of range
