"Workspaces" Endpoint - POST Create Rates
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/rates
Creates a new rate.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/rates".to_string()).json(&serde_json::json!(\{"amount":"number","level":"string","level_id":"integer","mode":"string","start":"string","type":"string"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Body​
amount number Amount of the rate, required, must be greater than 0
level string Level of the rate, required, must be one of: ‘workspace’, ‘workspace_user’, ‘project’, ‘project_user’, ‘task’
level_id integer Identifier of the level, required
mode string Mode of the rate, required if Start is not informed, must be one of: ‘override-all’, ‘override-current’, ‘start-today’
start string Start date time of the rate, required if Mode is not informed, must be a valid date time
type string Type of the rate, required, must be one of ‘billable_rates’, ‘labor_rates’
201​
Successfully created.
Possible error messages:
  • Request payload must be informed
  • Invalid workspace ID
402​
Billable rates are available for Starter and higher plans.
User cannot access billable rate(s).
