"Workspaces" Endpoints - POST Create a new workspace
https://api.track.toggl.com/api/v9/organizations/{organization_id}/workspaces
Create a workspace within an existing organization.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/api/v9/organizations/{organization_id}/workspaces".to_string()).json(&serde_json::json!(\{"admins":[\{\}],"default_currency":"string","default_hourly_rate":"number","initial_pricing_plan":"integer","limit_public_project_data":"boolean","name":"string","only_admins_may_create_projects":"boolean","only_admins_may_create_tags":"boolean","only_admins_see_billable_rates":"boolean","only_admins_see_team_dashboard":"boolean","projects_billable_by_default":"boolean","projects_enforce_billable":"boolean","projects_private_by_default":"boolean","rate_change_mode":"string","reports_collapse":"boolean","rounding":"integer","rounding_minutes":"integer"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
organization_id integer true Numeric ID of the organization
Body​
admins Array of integer List of admins, optional
default_currency string Default currency, premium feature, optional, only for existing WS, will be ‘USD’ initially
default_hourly_rate number The default hourly rate, premium feature, optional, only for existing WS, will be 0.0 initially
initial_pricing_plan integer The subscription plan for the workspace, deprecated
limit_public_project_data boolean Whether the workspace limits public projects data in reports to admins.
name string Workspace name
only_admins_may_create_projects boolean Only admins will be able to create projects, optional, only for existing WS, will be false initially
only_admins_may_create_tags boolean Only admins will be able to create tags, optional, only for existing WS, will be false initially
only_admins_see_billable_rates boolean Whether only admins will be able to see billable rates, premium feature, optional, only for existing WS. Will be false initially
only_admins_see_team_dashboard boolean Only admins will be able to see the team dashboard, optional, only for existing WS, will be false initially
projects_billable_by_default boolean Whether projects will be set as billable by default, premium feature, optional, only for existing WS. Will be true initially
projects_enforce_billable boolean Whether tracking time to projects will enforce billable setting to be respected.
projects_private_by_default boolean Whether projects will be set to private by default, optional. Will be true initially.
rate_change_mode string The rate change mode, premium feature, optional, only for existing WS. Can be “start-today”, “override-current”, “override-all”
reports_collapse boolean Whether reports should be collapsed by default, optional, only for existing WS, will be true initially
rounding integer Default rounding, premium feature, optional, only for existing WS
rounding_minutes integer Default rounding in minutes, premium feature, optional, only for existing WS
admin boolean Current user is workspace admin Deprecated
api_token string deprecated
at string Timestamp of last workspace change
business_ws boolean Workspace on Premium subscription
csv_upload object CSV upload data
hide_start_end_times boolean -
ical_enabled boolean Calendar integration enabled
ical_url string URL of calendar
id integer Identifier of the workspace
last_modified string Last modification of data in the workspace
limit_public_project_data boolean Limit public projects data in reports to admins.
logo_url string URL of workspace logo
max_data_retention_days integer How far back free workspaces can access data.
name string Name of the workspace
organization_id integer Identifier of the organization
permissions string Permissions list
premium boolean Workspace on Starter subscription
profile integer deprecated
projects_billable_by_default boolean New projects billable by default
projects_private_by_default boolean Workspace setting for default project visbility.
rate_last_updated string Timestamp of last workspace rate update
role string Role of the current user in the workspace
rounding integer Default rounding, premium feature, optional, only for existing WS. 0 - nearest, 1 - round up, -1 - round down
subscription object deprecated
suspended_at string Timestamp of suspension
te_constraints object Time entry constraints setting
working_hours_in_minutes integer Working hours in minutes
csv_upload​
at string -
log_id integer -
subscription​
auto_renew boolean -
card_details object -
company_id integer -
contact_detail object -
created_at string -
currency string -
customer_id integer -
deleted_at string -
last_pricing_plan_id integer -
organization_id integer -
payment_details object -
renewal_at string -
subscription_id integer -
subscription_period object -
workspace_id integer -
card_details​
added_at string -
card_number string -
card_type string -
creator_id integer -
creator_name string -
expiry_date string -
holder_name string -
contact_detail​
company_address string -
company_city string -
company_name string -
contact_detail_id integer -
contact_email string -
contact_person string -
country_id integer -
country_subdivision_id integer -
created_at string -
is_eu_resident boolean -
updated_at string -
user_id integer -
vat_number string -
vat_number_valid boolean DEPRECATED
vat_number_validated_at string DEPRECATED
zip_code string -
payment_details​
created_at string -
currency string -
payment_type string -
reference string -
user_id integer -
subscription_period​
created_at string -
finished_on string -
started_on string -
subscription_period_id integer -
trial boolean -
user_count integer -
te_constraints​
description_present boolean -
project_present boolean -
tag_present boolean -
task_present boolean -
time_entry_constraints_enabled boolean -
Possible errors:
  • JSON is not valid
  • workspace name must contain non-space characters
  • workspace name must not be nil
  • workspace name must not be longer than 140
  • another workspace with same name exists in organization
  • user can have a maximum of 100 workspaces
  • Multiple workspaces are not enabled in this organization.
  • Organization {name} can have a maximum of {amount} workspaces
  • User with id {id} does not exist.
  • User {userID} not exists in the workspace.
402​
Possible errors:
  • Must be a premium user to use default_hourly_rate
  • restricting tag management to administrators requires a premium subscription
  • Must be a premium user to use default_currency
  • Must be a premium user to use rounding_minutes
  • Must be a premium user to use only_admins_see_billable_rates
  • Must be a premium user to use projects_billable_by_default
Forbidden
404​
Possible errors:
  • Organization not found/accessible
  • Workspace not found/accessible
  • organization owner not found
