Adjust time entries with clicks and/or arrow-up and arrow-down in the web app
I forget a lot to start the timer
I also, sometimes, end it too soon
After that, when I went to edit the time entries in the web app, I have to change the numbers by remove some and tapping from the keyboard the correct ones
I would like to have a way to use adjust start time and stop time by pressing arrow-up and or arrow-down
Or having a little arrows, up and down I go click on
It would be a lot easier
PS: I have ADHD
Do you need to have exact times? Sometimes I just drag the top/bottom of the box to the nearest 10-15 minutes because for me it’s close enough, rather than actually typing in the time.
I ended up doing the drag action through the desktop application, because you can adjust the “snap” variables to 1 minutes.
