Simultaneously adjust the time boundary between two entries
I repeat the same series of steps throughout each day: return to an earlier task, then realise – several minutes into it – that Toggl needs updating (via Toggl Desktop on Windows). I click the Play icon from an earlier instance to initiate a new timer with the same Description and Project, adjust the Start time of the currently running timer back a few minutes, then adjust the Stop time of the previous timer to match.
You’d think switching to Calendar view and dragging the slider on the boundary upwards might accomplish this, but it only adjusts the Start time of the current timer backwards. This creates an overlap, which forces the current timer to occupy the position to the right (shown below).
Is there a way of doing those last two operations simultaneously? Thanks!
