Assign two or more projects to a single time entry
Hello, I am new here and with Toggl track too.
I would like to have a time entry that corresponds to several projects.
Is it possible to do this? Unless I am mistaken, I do not see the information anywhere.
Context:
I have a large project, which includes several small projects.
I would like to track the time of this large project as a whole, but also each sub-project individually.
Thank you for your help
Hi Mitsu
I always use the clients as the level for projects. So, every project is a client. Here are a few examples of clients:
  • Company A _ SAP GTS Implementation
  • Company A _ Optimizing SAP TMS, plant @New Orleans)
  • Company B _ Pre-order phase
I use the projects for the “smaller projects” or, better said, “main tasks.” In my world, a main task is a Jira ticket for defining, coding, testing, and delivering IT functionality.
If I need more layers for work planning and progress/budget control, I add tasks to a “project”.
I do not use the invoicing function, so I do not know if my method of doing it would also work for you.
Hi Markus,
Thank you for your answer and the trick, I’ll see if it could suit me (even if I would have to update everything that is already done)
For invoicing, I don’t use it either, it’s for my own Patreon projects, I am a content creator, and alone.
Thanks
