[BUG] Pop-up hidden behind frame
Toggl Track
Topic content
I use Toggl Track every day (original, not 2.0; web browser on desktop interface). Something has suddenly changed, so that when I go to edit recent time entries, the pop-up that allows editing gets hidden behind the frame on top. This prevents me from editing times and from adding tags that start with A. It happens in both Safari and Chrome, and is not affected at all by changing the magnification.
That does sound frustrating, especially since it’s blocking editing and tag entry. This looks like a display/rendering bug in the Toggl Track web app, and the fact that it happens in both Safari and Chrome (and isn’t affected by zoom level) suggests it’s something on Toggl Track’s end rather than a browser-specific issue.
A few things worth trying in the meantime:
  • Try using the keyboard to navigate the edit popup - the Tab key moves between fields and the spacebar makes selections, which might help you reach fields that are visually obscured.
  • For tags starting with A specifically, you could try typing more characters after the A to narrow down the list, which may shift how the suggestions render.
  • Clearing your browser cache and doing a hard refresh (Ctrl+Shift+R or Cmd+Shift+R) occasionally resolves sudden UI changes like this.
Since this appeared suddenly and affects multiple browsers, it’s likely a recent change to the web app that has introduced a z-index or layering issue with the edit popup. It would be worth checking if other community members are seeing the same thing, as a pattern of reports helps confirm it as a wider bug.
