Tags broken?
Did something break with tags? Today for the first time, I can’t edit tags on my existing time entries (including entries that I just created today).
The time entry shows the tag icon. When I click on the time entry, it shows my tag name. But when I click on the tag name to change/delete the tag, I get text stating “there are no tags get.”
This is happening on Win10, both Chrome and Edge browsers. Same behavior in Chrome on Android.
For me only the tags in the currently running entry don’t load. As soon as I hit the tag button in existing entries the tags load for the currently running entry as well.
Thank you for your reply.
The tag behavior is different today, but still broken. Rather than showing me a message that “there are no tags yet” for time entries that do have tags, it’s showing me the tag. However, when I try to click on the tag to uncheck it (and thus remove the tag), the tag’s checkbox is already unchecked.
Frustrating.
Following, similar issue
Hi,
We are working on a fix. We will update here when it is resolved.
As of Apr. 11, the tags seem to be working normally again.
