Toggle widget display bug in Noushena
Good afternoon
I don’t know where to write about this, but the time-adding widget inside Notion has looked like this for years.
It works in all browsers: Chrome, Edge, Brave, all the popular ones.
Thanks for reporting this issue with the Toggl widget display in Notion. It sounds like there’s a visual bug that’s been affecting the time-adding widget across different browsers.
Since I’m unable to see the image you’ve attached, could you describe what the display issue looks like? For example, is the widget not showing up at all, appearing misaligned, or displaying incorrectly in some other way?
Once I understand what’s happening, I can better help you troubleshoot or find a workaround. In the meantime, if you haven’t already tried it, you could test whether the issue persists if you clear your browser cache or try accessing Notion in an incognito/private window to rule out any cached data causing the problem.
Hi. Thank you for responding. Are you AI agent?
Hi Dmitri! We do have some AI assistance to help us better triage questions and get them to the right people :slight_smile:
Human here this time :waving_hand: Can you let me know what browser you’re using Notion in, and what version of the Toggl extension you have installed?
Hi! I Use Toggl Track: Productivity & Time Tracker Version 4.5.1
Inside Edge Browser Version 148.0.3967.54 (Official build) (64-bit)
This toggl extension was installed from Edge Extension Store
