Bulk Archive & Delete: How It Works
Overview
The bulk archive and delete feature gives you a cleaner, more organized workspace — without losing access to your historical data. This article explains how archiving and deleting works for projects and tasks.
Archiving Projects & Tasks
You can bulk select and archive or delete:
  • Projects
  • Tasks — either from within a project view or from the task list
When you archive a project, all tasks under that project are automatically archived too.
Archived Tasks on the Timeline
Archived tasks are retained on the timeline so you can still reference historical data. If you want to remove them from the timeline entirely, you’ll need to manually delete them.
What You Can (and Can’t) Do with Archived Items
Action Possible?
View in reports :white_check_mark: Yes
View on timeline :white_check_mark: Yes
Edit or manipulate directly :cross_mark: No
Unarchive to make edits :white_check_mark: Yes
Archive tasks or subtasks within archived entities :white_check_mark: Yes
Editing Archived Items
To make changes to an archived task or project:
  1. Unarchive the item
  2. Make your edits
  3. Re-archive if desired
Coming Soon
Bulk archive and delete is the first step toward full bulk edit capabilities. More bulk editing features are planned for a future release.
The bulk archive and delete feature lets you clean up your workspace while keeping your historical data intact.
You can bulk select and archive or delete projects and tasks. When you archive a project, all its tasks are automatically archived too.
Here’s what you can do with archived items:
  • View them in reports and on your timeline
  • Unarchive them if you need to make edits
  • Archive tasks within archived projects
What you can’t do:
  • Edit or manipulate archived items directly
If you need to edit an archived item, unarchive it first, make your changes, then re-archive it if needed.
One thing to note: archived tasks stay on your timeline so you can reference historical data. If you want to remove them from the timeline entirely, you’ll need to delete them instead of archiving.
