Archiving projects
To reduce clutter in your workspace, archive any projects that you no longer use.
Archiving projects is a better way of clearing up your workspace of existing projects you no longer use than deleting them or if you are on the Free plan and need to create new projects. An archived project can be restored at any time should you need to restore it.
To archive a project
  • Locate it on the “Projects” page,
  • Hover over the project you’d like to archive
  • Click on the three dots on the right and then click on Archive.
Restoring archived projects
Viewing archived projects:
To restore an archive project use the “Active” filter on the “Projects” page and select “Archived”.
Restoring projects
You can use the rest of the filters to pinpoint the project you need, once you locate it, hover over the Project that you want. On hover, three dots will appear on the right side, click on it and then click on Restore.
