I run the report shown in the image daily. Since I never reference the huge default bar and pie charts at the top of this report (1), I would love to have the option to (persistently) toggle them off to immediately see the data that matters (2) without scrolling. Thanks!
The ability to persistently hide charts in reports is not currently available in Toggl. This sounds like a great idea though, as it would let you customize your reports to focus on the data that matters most to you without scrolling past visualizations you don’t need.
In the meantime, a workaround would be to use your browser’s developer tools to hide the chart sections on the page, though this wouldn’t be a persistent setting across sessions. Another option is to export your report data if that functionality is available for your report type, which might give you a cleaner view of just the numbers you’re interested in.
