Toggl services are fully operational. However, a major Cloudflare outage is affecting many internet services today, which may impact your integrations with other tools.
What’s Happening
A global Cloudflare infrastructure issue began at approximately 11:20 UTC due to unusual traffic spikes. CNBC While Toggl doesn’t use Cloudflare, many popular services do, including:
Confirmed affected services:
- Slack
- ChatGPT/OpenAI
- Spotify
- Dropbox
- Shopify
- Coinbase
- Various project management tools
What This Means for You
Potential integration issues you might experience:
Toggl tracking works normally
Sync failures with project management tools
Webhook deliveries may fail or delay
Zapier/Make/n8n automations might error out
Calendar sync issues (if your calendar provider uses Cloudflare)
Slack notifications may not deliver
Recommended Actions
If your integrations are failing:
- Don’t panic - Your time tracking data is safe in Toggl
- Manual workaround - Continue tracking normally; integrations will sync when services recover
- Retry later - Most integrations will automatically retry failed syncs
- Check status pages - Verify if your specific integration partner is affected:
- Cloudflare Status
- Your integration provider’s status page
Expected Timeline
Cloudflare identified the issue at 13:09 UTC and is implementing fixes, with some services already recovering. Tom’s Guide; The Denver Post; Based on typical infrastructure incidents:
- Next 1-2 hours: Gradual service restoration
- Failed syncs: Should automatically retry once services recover
- No action needed: Unless you have time-sensitive integration workflows
Bottom Line
- Your Toggl data is safe
- Time tracking continues normally
- Integration issues are temporary and should self-resolve
We’ll update this thread if the situation changes significantly. Feel free to share which integrations you’re seeing issues with in the comments - it helps other users know what to expect.
