Toggl Track Not Syncing and focus.toggl.com Is Blank
Toggl Track
Topic content
I’ve been using Toggl for over 12 years at this point, and I just logged into the website focus.toggl.com and all of my events are gone. It is blank. I know they were there just a few weeks ago, so I’m not sure what’s happening. I’m still able to use Toggl Track Version 10.17.0 (2993). But two things seem to be happening. #1 - sync is no longer happening. #2 - all of my past events are gone. I found this email in a junk folder today "Hello,
We hope Toggl 2.0 has brought more clarity to your days already. Just a quick heads-up — your Premium trial ends in 7 days.
If you’d like to keep using features like Timeline view, Billable rates, Workload and Utilization reports and more, you can upgrade with one click here.
Not planning to upgrade? No problem – in 7 days your account will simply switch to the Free plan, and you can keep using Toggl 2.0.
Need help or have questions before upgrading?
Check our help articles or ask in our Community — our team will be happy to help." Is it related? How do I rectify all of these issues? With the free plan, I should still be able to see all of my past events, and it should be syncing, right?
The good news is that your past data is not gone — it is still there. What you are seeing at focus.toggl.com is Toggl (formerly Toggl 2.0), which is a separate product from Toggl Track. The two have different data, so your Toggl Track history would not appear in Toggl unless it was explicitly imported.
The email you found is about your Toggl Premium trial ending. That trial expiring would not affect your Toggl Track data or sync at all — those are independent.
Regarding the sync issue you are seeing in Toggl Track Version 10.17.0, that is not something covered here, but your data in Toggl Track itself should be unaffected by anything happening on the Toggl side.
If you want to bring your Toggl Track history into Toggl, there is an import process for that. You can find details at Importing data from Toggl Plan and Toggl Track to Toggl
As for the free plan on Toggl — yes, you can continue using Toggl on the free tier after your trial ends, though some premium features like Timeline view, Billable rates, and Workload and Utilization reports will no longer be available.
