I am connected to the toggl treck app to track my work hours. Every few hours I receive a notification on my mobile that says: you have entities that faild to sinc 2 projects. How can I identify the projects that failed to sync so that this message no longer appears on my mobile? I tried going through all my projects and the times I captured and couldn’t find the cause of the projects that are failing to sync. What do I do?
@Gal_Tsoref thanks for posting!
If everything looks good when you compare your data between the mobile app and the web app, and you can’t see any
or
error icons next to your time entries in the mobile app please log out of the mobile app and log back in. This action clears local data and should get rid of that error message for you.
Thank you very much!!!
I did what you wrote and it seems to have worked.
בתאריך יום ד׳, 11 ביוני 2025 ב-11:11 מאת Veljko via Toggl Community <notifications@toggl.discoursemail.com>:
Nice! Thanks for the update ![]()
