Problem: Goals use OR logic for tags, causing entries to count toward multiple goals simultaneously. An entry tagged “#DeepWork #CompanyA” inflates progress for both a DeepWork goal AND a CompanyA goal.
Use Case: I tag work type (#DeepWork, #ShallowWork) and context (#CompanyA, #Personal). I need separate goals for:
3 hours: #DeepWork AND #CompanyA
1 hour: #DeepWork AND #Personal
Why existing options don’t work:
Projects: Can’t filter by client, only by individual projects
Combined tags (#CompanyADeepWork): Creates tag proliferation, loses flexibility
Request:
AND logic for goals (require all criteria)
Ability to edit goal criteria after creation
