I run Toggl Track Desktop 10.11.2 on two Windows 10 workstations, logged in using the same Toggl account.
A local PowerShell script is used to create Toggl Track projects via the API (perhaps not significant).
Somehow, multiple copies of the same project have been created. They’re visible in both copies of Toggl Track Desktop, suggesting it’s not a local cache issue.
All but one entries (the last) have disabled Edit and Archive options when the vertical ellipsis is clicked.
Doing the same search for 18515 via the web site’s Projects list, with Show All checked, only the editable project is listed.
Is it possible to find and delete the other instances of this project?
Thanks!
Edit: Please ignore!
Have just read Recently deleted projects still appear in the toggl Track App and logging out and back in again does indeed remove the unwanted local items.
Thanks all.
