“Projects” Endpoints - PATCH Patch project users from workspace
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/project_users/{project_user_ids}
Patch a list of project users for a given workspace.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::PATCH, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/project_users/{project_user_ids}".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Query​
project_user_ids integer true Numeric IDs of the project users
failure Array of object List of found errors
success Array of integer List of org user IDs that were successfully patched
failure​
id integer Organization user ID
message string Found error message
Possible error messages:
  • Invalid value as user IDs
  • No patchable fields defined
  • PATCH expects at least one ID
  • PATCH request is limited to %d entries at once
  • Invalid op:
  • Invalid path format:
  • Path not found:
  • Operation not supported ({patch_operation} {patch_path})
  • Invalid path
  • /manager expects a boolean
  • /labor_cost expects an float64 or null
  • /rate expects an float64 or null
  • Operation not supported (add /labor_cost)
  • Operation not supported (add /rate)
  • Operation not supported (add /manager)
