"Tasks" Endpoints - PATCH Workspace Project Tasks
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects/{project_id}/tasks/{task_ids}
Patch project tasks for given workspace.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::PATCH, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects/{project_id}/tasks/{task_ids}".to_string()).json(&serde_json::json!([\{"op":"string","path":"string"\}]))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
project_id integer true Numeric ID of the project
task_ids string true Numeric IDs of project tasks separated by comma
Body​
items Array of object -
items​
op string -
path string -
failure Array of object -
success Array of integer -
failure​
id integer -
message string -
Possible errors:
  • Invalid project_id
