“Projects” Endpoints - PATCH Workspace Projects
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects/{project_ids}
Bulk editing workspace projects.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::PATCH, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects/{project_ids}".to_string()).json(&serde_json::json!([\{"op":"string","path":"string","value":\{\}\}]))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
project_ids string true Numeric IDs of project ids, separated by comma. E.g.: 204301830,202700150,202687559
Body​
items Array of object -
items​
op string Patch operation to perform, one of “add”, “remove”, “replace”
path string Path to the field to patch, example: “/color”
value object Value to set when operation is “add” or “replace”, example: “#000000”. The value type actually depends on the field being patched.
value​
failure Array of object -
success Array of integer -
failure​
id integer -
message string -
How can I update the active attribute via the API so the project is archived?
Hi @Mike_Meesseman so sorry for the radio silence here.
Checked with the team, from what I understand, you can set the active flag in PUT /workspaces/{workspace_id}/projects/{project_id}
Does that help?
Yes, this seems to work. Thank you!
