How can i recover a deleted project?
I’m afraid that it is not possible to recover a deleted project if you didn’t use the
“undo” option right after deleting it.
If you normally allocate time entries to a project, you can:
- Recreate the project
- Go to the Detailed Report page
- Apply the appropriate date range
- Use the project filter to view time entries without a project.
- Select time entries by using the main check-box at the top or hovering over individual ones and clicking on the boxes next to them
- Edit selected entries in bulk to allocate them to the newly created project
I know this is a bit of a hassle, but unfortunately, there’s no other way to get things back to their original state. Deleting a project also means that all the time entries associated with it lose that association. If you are unsure which entries to allocate to the new project, you can always refer to the weekly automated reports we send out via email as use that as a reference.
