Snapping an activity to an existing activity
Hi,
It would be nice to be able to snap an activity to the end of a previous activity.
That’s a good idea! The ability to automatically snap a time entry to the end of a previous activity is not currently available in Toggl.
As a workaround, you can manually adjust the start time of a time entry by editing it. When you open a time entry to edit, you can set the start time to match the end time of your previous activity, which achieves a similar result.
I appreciate you sharing this suggestion. We’ll make note of it for the product team to consider for future updates.
Hi Support, is this feature in the roadmap for the Windows desktop app? I for one would be very appreciative. Thank you.
