Toggl
Topic content
Hi there,
I’m not sure what I’m doing wrong but I can’t find the option to show the bar charts with the stacked bars on the summary report to visualize the breakdowns I’m choosing in the table below - usually client & project?! I also couldn#t find it here in the community :-/
Thanks for any pointers.
Best,
Mario
The stacked bar chart option in the Summary Report was removed at some point, which is why you can’t find it. It’s no longer available there.
The good news is that you can build something similar using My Reports (available on paid plans). There you can add a grouped bar chart and configure it to show time broken down by project or client. Here’s a quick way to set one up for a “Data Trends” style view:
Go to My Reports, click “New Report”, add a “Grouped bar chart”, then configure it with:
- Show: Time
- Bars represent: Projects
- Cluster projects by: Day or Weekday
You can also filter by specific projects to keep it readable.
For a more detailed guide on building these charts, including how to replicate older Insights views, take a look at this article: How to build Insights charts in Reports | Toggl Knowledge Base
One thing to note: if you want to stack by team member rather than project, the colors for members are randomly assigned and can’t be customized. However, you can set colors per project, and the bar chart will use those when stacked by project.
