Stream Deck using too many requests from user specific requests quota
Every time I use my Stream Deck to create a Toggl Entry, I use 1 request in my organization, but also 4 requests from user specific requests quota, which dramatically limits my use of my Stream Deck to create Toggl entries.
This can’t be right. Is there anything I’m doing wrong? If the Toggle plugin for Stream Deck only used 1 request from user specific requests quota, I would have a maximum of 15 Toggl entries per hour (1 request for starting the timer and another one to terminate it).
Right now, I need 4 to start the timer and another 4 to terminate it, which limits my workflow significantly.
Thank you.
Did you end up finding a fix for this?
Also struggling with this!!! Let me know if you find a fix..
