Tags dissapearing after first assignment
Hi,
I’m currently experiencing a weird bug in the Toggl Track web app.
When I create a time entry, I can assign a project and then add a tag, usually a ticket number. However, the tag disappears after a few seconds. If I assign it again, it stays as usual.
I tested this in Chrome and Firefox, including private mode.
It looks like a new bug.
I first noticed it last week in my reports, where the tags were missing, and now I’ve caught it happening live.
I can reproduce the issue right now: I just have to wait for the tag to disappear the first time, then set it again.Happends with new and old tags.
I’d appreciate any feedback on whether this is already a known issue.
Thanks.
Thanks for the detailed report, and for testing across multiple browsers including private mode - that really helps narrow things down.
This does sound like a bug. The workaround you found, assigning the tag a second time for it to stick, is a reasonable temporary fix in the meantime.
Since this is happening consistently and across different browsers, it is worth noting that other community members can confirm here if they are seeing the same behavior, which helps identify how widespread it is.
I will make sure this gets flagged to the team for investigation.
Same behaviour for a few weeks now. This might become a reason to start to look elsewhere.
Hi there,
Thanks for the reply!
Can you both let me know if you happen to have Toggl 2.0 two way sync enabled and whether this behaviour is still happening?
If you can both let me know where you’re starting your time entries from, that would be great :blush:
Hi,
i had the 2 way synch on but was using the “old” track. But i just turned it off and the error is gone. So i guess they will be no synch for now.
Hi,
This issue has been resolved.
