When I begin to type the description of an entry, on every platform, I see the previous entries with similar description.
When I select one of them, the timer start with the same description and project, on every platform, consistently.
(every platform = web app, macos app, android app…)
But, the TAG(s) is/are not assigned on android, whereas it is the case on the MacOS app, and in the Web App…
This is confusing, and it’s really shame it’s not the same behavior on the android app!
Because of that, it’s painful to use. Each time I select a previous entry from the autocomplete list on android, I have te assign the tag(s) by hand on android.
I use tags a lot, and I use also my smartphone a lot to log entries with Toggl.
Could you please fix this?
