Toogl Track data import problem
I’ve imported all the data from Toggl Track, but in 2.0 (Focus) I have now days when I’ve worked 40+ hours. What can cause this problem. It looks like, in Focus all records of all organisation members are assigned to me.
(The track report page is so much better.)
That does sound like a frustrating issue! Based on what you’re describing, it seems like the import may have pulled in time entries from all members of your organisation and assigned them to your account, which would explain the inflated hours.
Unfortunately, the knowledge base does not contain specific details about how the Toggl Track to Focus (2.0) import handles multi-member organisation data, so I cannot confirm the exact cause from here.
What you can do is go through the imported time entries and manually delete the ones that do not belong to you. It may also be worth double-checking the import settings or source file if you used a CSV import, to see whether it included entries from other team members.
I will make sure to pass along your feedback about this import issue, as well as your note about the Track reporting page, to the product team.
