I keep seeing an error that a project is archived, but I can’t see which one. If I could see which project is archived, I could update it. The error occurs when I refresh.
That’s frustrating to see an error without knowing which project it refers to. Unfortunately, this is not currently possible in Toggl - the error message doesn’t display the project name that’s archived.
As a workaround, you can check your projects list to find which one is archived. Archived projects are typically marked or separated in your projects view, and you can unarchive the project from there. Once you identify and unarchive the project, the error should no longer appear when you refresh.
If you have multiple projects and it’s difficult to spot which one is archived, you might also try creating a new time entry to see if any of your active projects show up differently, or review your recent time entries to see which projects you were working with before the error started appearing.
