Filtering Reports
Use Filters to find relevant data.
Toggl Track reports can be filtered by User, Client, Project, Task, Tag, Billable flag and Description. Changes made to individual filters will be applied as soon as you click outside of the filter field. To generate the report, click outside the dropdown box.
Filtering Features and Suggestions
  • Do not set any filters if you want to show all the available data.
  • Selecting a client inside the Client filter will automatically select all projects related to that client. Do not interact with the Client filter unless you are creating a report for all projects associated with that client.
  • Selecting a project inside the Project filter will cause the Task filter to only show tasks related to that project.
  • You may select up to 1000 items in total across all of the filters.
  • By default, reports will show you data from active and archived projects, you can change this by selecting all active projects if you only wish to see data from those projects.
Filtering Projects
Note: Premium plans will also see an Audit filter on their Detailed Report.
Need more help or have suggestions for improvements? Contact our support team via chat using the purple chat button in the bottom-right corner.
Hi @Support ,
I looked up the filtering option on your website as well, but the functionality has been changed recently (I think it was around 8 weeks ago)
Now, when I create a project, I get another filter option named “My Projects”. Because we have a lot of projects within our organization (we’re a software development agency) it’s not user friendly.
I can’t find any setting (I hope there is one) to disable this option.
Next to this problem, for as far as I know (and can find) there are/were no release notes and/or roadmap of the application in general. So sometimes (like this one) updates get pushed to production without us knowing that suddenly something has changed.
I’m using the webapp!
@RoyvanRingelenstein thank you for this feedback! This change was relatively recently introduced (Oct 3rd, 2023). There was no announcement about the change. I looked into it. It didn’t feel like it would have a major usability impact. There are no settings to disable it as of now.
I shared your feedback with the Product team members and hope to provide you with better options in the future.
This is one of the things we are looking to change with this community. We’re just getting started, but we do want to be more in touch with our users on all fronts, including product changes, no matter how big or small. Thanks for sharing that!
All of our filters are empty in the Reports tab. No Clients, no Projects etc. are found. This is a recent development. Please advise how to fix, we need this for billing. Thanks.
Hi there!
This should be resolved by the time I post this reply. Can you confirm?
Yep, fixed - thanks!
Many of my reports default to having a client filter applied. I have a total of 19 clients all of which are active. The filter always defaults to Client is one of 19 selections and selects 17 of my 19 clients.
What criteria is it using to select those 17 clients? I’m puzzled why it excludes 2 of my clients - particularly when one of those has multiple times tracked to active projects within the timeframe I’m reporting on. The second one that isn’t included hasn’t had activity in months, so I’m less concerned that it isn’t being selected.
Is there a way to set defaults so that I don’t have to keep changing the filter?
Please note that this behavior has been happening for months and is unrelated to any of the new report features rolled out.
Is there something different about this one client that prevents it from being automatically included in the filter?
Hi Carlene! If I understand correctly when you visit the Reports tab the report auto-populates 17 clients, and excludes two specific ones consistently?
Yes! That is an accurate assessment.
Hey Carlene,
Can you please try clear your browser cache or log in via an incognito browser session and let me know if this continues?
Thanks!
