"Start timer" button not working in Gmail
The “Start timer” button has not been working in Gmail for the past couple of days. It works in Google Docs, so it seems to be limited to Gmail.
I’ve cleared the Chrome browser and Gmail cache, restarted Chrome, and rebooted the computer to no avail.
Any suggestions?
I understand how frustrating that must be, especially since it’s working fine in Google Docs for you.
Since the Toggl browser extension works in some Google apps but not Gmail, here are a few things you can try:
First, make sure the Toggl extension has permission to run on Gmail. Check your Chrome extension settings and verify that Toggl has access to mail.google.com specifically.
If permissions look good, try disabling and re-enabling the Toggl extension. Sometimes this refreshes the connection between the extension and the webpage.
You could also try using an incognito window in Chrome to see if the button works there. This can help rule out conflicts with other extensions.
As a workaround in the meantime, you can always start your timer directly from the Toggl web app or mobile app and add the Gmail task details manually, or use the browser extension on a different Google service and update the description afterward.
If none of these steps resolve it, the issue may be specific to your setup, and there could be browser-specific factors at play.
I have the same issue, started several days ago. When clicking “Start Timer” in GMail, it does nothing. It works in other places where I use it (Github, Azure etc).
GMail must have changed something on their side, can you get it to work again please?
I already tried turning off the GMail option in the extension settings, and turning it back on. Must be something in the GMail javascript that is interfering with the extension.
Hi Nikola! Can you share what version of the extension you currently have installed?
It’s version 4.11.10 for Firefox
I have the same issue, but in Todoist. A few days ago, the Start time button stopped responding. Extension version 4.11.10 Chrome
Thank you, Nicola!
I’ve sent this to the team to investigate :slight_smile:
Hi Meshi,
The team are aware of this issue with Todoist and are looking into it.
Thanks!
Gmail is enabled in the extension’s permissions, and deleting/reinstalling the extension did not bring the Start timer button to life in Gmail. I also tested it in incognito mode and it’s not working there, either.
Heya,
Thank you for the wait on this! Our team has released an update to the extension that should properly address this issue for you; it’s being rolled out to all users now, so just keep your extension updated for version 4.11.12 . Thank you!
The “Start timer” button just started working for me. I’m not sure exactly when, because I had stopped testing the button daily when it became apparent that it hadn’t been fixed. But I think the last time tested it was three days ago. And today it’s working! Callooh! Callay! Thanks for fixing it. :folded_hands:
