Time entries are not always saving
There has been a bug where my time entries were being deleted and it may been since I added the chrome extension. I hadn’t noticed it before.
Example: I hit start and go off to other tabs to work, when I return to the Toggl tab in the browser I see the amount of time that I have been working, then there is a glitch and the time entry does not save and does not enter, the timer looks as if it was off. Very strange.
Hopefully removing the chrome extension helps.
This has been happening for roughly two weeks, as far as I am aware, maybe a little longer.
Rob
@Rob_Faulkner, thanks for sharing this, and sorry for the late reply!
The issue should be resolved with the latest update for the extension: Version 4.7.0
